02-22-2021 06:13 AM - edited 02-22-2021 06:19 AM
the led 1 and 2 doesn't turn on
02-22-2021 12:43 PM - edited 02-22-2021 12:44 PM
Did you calculate how much current they you get across two 1KOhm resistors in series? How much current do they need to light up (probably more than 6mA)?
02-26-2021 12:09 AM
Hi danizunich and altenbach,
The values of resistors as pointed out by altenbach may have merit but the main problem might be somewhere else.
Switches S1 and S2 are both controlled through the A key. S1, however, is normally open while S2 is normally close. Analyzing the circuit, we can see that the two LEDs cannot be lit simultaneously.
With S1 closed (S2 open), LED1 will glow if the voltage in the capacitor is low enough for adequate current to flow through this first LED. As the capacitor charges up the light emitted by LED1 will become fainter. When the A key is pressed the switches toggle states, S1 opens turning LED1 off, S2 closes providing a current path from the capacitor to R2 and LED2. If the voltage in C1 is sufficient to forward-bias LED2, this LED turns on. As the capacitor discharges the light emitted by LED2 becomes fainter.
To obtain this predicted behavior the following should be done first:
Very likely, the capacitor is not initialized and Initial conditions in Simulation settings is set to Determine automatically (the default). This results to strange behavior of the circuit.
G. Goodwin
