Multisim and Ultiboard
CD4020
Hello everyone,
I am trying to get different outputs from a 14 stage binary counter. I am using for reset a 100nF capacitor connected to ground and for clock an oscillator made of 2 nand gates. The counter that I am using is 4020BD_5V.
I used a probe to check the input from the clock (which varies between  0 and 5V) and a probe to check the output at the first pin. Why is the output always 0V?
Thank you so much
(1,089 Views)
Hi Patricia25,
... I am using for reset a 100nF capacitor connected to ground ... The counter that I am using is 4020BD_5V.
The RESET input of CD4020 (4020BD) is active high not active low. Try connecting the capacitor from RESET to +5 V (Vdd). Don't forget the resistor (1 kΩ to 10 kΩ) from RESET to Vss (ground).
G. Goodwin
(1,038 Views)
