10-01-2007 05:37 AM
10-01-2007 08:36 AM
I can at least confirm this behaviour as you described it. I just finished doing a test using your procedure and it did truncated the name after the space and I was also unable to delete or rename it afterwards. Worst case scenario is that you will have to delete the busses and start over. This is the only way I can see to elimate that line. Or you can continue on and just not hook any lines to it and it may be fine.
This is definitely a software issue that needs attention.
Have A Nice Day
10-05-2007 05:40 PM
I have a question about this behavior for both of you.
I'm trying to replicate it and whenever I type in: 12V RTN as the busline it changes it to 12V_RTN. Spaces are not allowed in the busline name, but whenever there is a space the software is supposed to add an underscore ( _ ) instead of the space. Is this not the case?
When you merge buses, you can rename any bus from the merge dialog.
What version are you using?... I'm trying to replicate this on 10.0.1, which if you go to Help > About Multisim shows as build 10.0.343. Please let me know if it is the same version, I want to be able to replicate this to report it.
10-05-2007 06:04 PM
I am using 10.0.1 and my build numbers are 10.0.343. I tried this and it did what he said it did, but I will go back and try it again to make sure. I will then post it for you to examine if it does still behave badly.
Be back with you soon.
10-05-2007 06:13 PM - edited 10-05-2007 06:13 PM
O.K. I tried it again and it still does the same thing. I will post it below and let you take a peek at it. This is just a simple circuit with 2 busses labeled Bus1. When you delete the lines, the label inside the bus is still there and you can't seem to remove it from the line list.
Here it is:
Message Edited by lacy on 10-05-2007 06:16 PM
10-05-2007 08:19 PM
10-05-2007 09:58 PM
I can can validate what he is seeing (It's always good that more than one person sees the same thing). The file I posted is the "drag line to bus" as he has stated in his post.
Have A Nice Day
10-08-2007 08:55 AM
Thanks for pointing that to me, I always use the other method, create the buslines first, then start connecting nets to it. But if you use the bus entry dialog to create the busline then I can confirm the behavior, spaces are not truncated. I will report this immediately to R&D so they can update their development plan.
Thanks!
