08-01-2007 12:41 PM
08-01-2007 01:03 PM - edited 08-01-2007 01:03 PM
Message Edited by kittmaster on 08-01-2007 01:05 PM
08-01-2007 01:34 PM
08-01-2007 02:23 PM
Alex, my bad, I did not tried all the shapes (thanks for suggesting the triangle -polygon)... and I can now see what you are reporting, I will immediately file this as a defect.
Chris, Alex, I am not in the interest to start a discussion of what is a bug and what is not. But I would like to explain what I mean when I make a distinction between them, I don't want you guys to take the impression that I am not being serious about your comments, I am, and we all at NI are, so let me explain what I mean when I call something a bug or a feature... A bug (defect) is something that is broken or is not working, or is not doing the correct task, such as the flip function Alex just reported, in that case that's considered a defect that needs to be fixed. In the case of the multi-letter RefDes, the ability to choose more than one letter is not available, you have a drop-down list with fixed selections you can choose from, the ability to choose multiple letters is not built in the software, you only can choose from the available options (single letter). This is a feature request we have to make in order to have the software the ability to let you choose multiple letters. If you were able to choose multiple letters and then it won't show them then that would be a bug. In this case is not, that is why I'm reporting it as a feature we need to add to let a user add more letters. If you currently need to add the extra letters you can do so after you place the component. Still, Multisim should follow the IEEE standard like Alex is saying and that is why we are requesting to R&D that they review that section and add that functionality that is missing.
08-01-2007 02:49 PM
08-01-2007 02:56 PM
08-03-2007 12:51 PM
08-08-2007 03:29 PM
I tried to replicate this problem but was not able to do so. Here is what I did:
1. Turn on the spreadsheet in Multisim
2. Click on the Nets tab
3. Under Trace to trace column (the value in this column is transferred to UB Trace clearance column) I entered a value.
4. It transferred correctly
5. I went back to MSM and modified the trace value and transferred to new UB file and it worked.
The only thing that I can see that will not work is if you were to forward annotate.
08-08-2007 10:27 PM
08-08-2007 10:45 PM
