10-20-2015 02:22 PM - edited 10-20-2015 02:22 PM
A coworker brought by a project file he created in Ultiboard 14 for me to look at, and I was unable to load it with Ultiboard 13. Are these completely incompatible?
Solved! Go to Solution.
10-20-2015 08:24 PM
as much as I figured, MS14 does open files *.ms13
but
MS13 does not open files *.ms14
best regards
Michael
10-21-2015 11:18 AM
Hi redwing196,
As aa232004 mentioned, the Multisim files are not backwards compatible, which should not allow you to open files created in newer versions of the software in an older environmnet. you can find a better explanation of this in the following Knowledge Base article
Hope that you can find this information helpful!
10-28-2015 07:03 AM
OK, thank you.
