Multisim and Ultiboard
Agilent Oscilloscope window cut off
Hello all, I'm new to Multisim and I have it installed on my Surface Pro3, I'm trying to view a file that uses the simulated oscilloscope, but the window is cut off. Is there a way to adjust it so I can see the entire oscilloscope? I attached an image of what I see.
(3,305 Views)
Have you already try it on a PC to check if the behavior remains?
(3,265 Views)
Apologies for the late reply, I am unable to try it on a PC since I don't have one. The only work around I found was to add a second O-scope and replace the one that was provided by the professor; after that it showed up normally. It appears to be an issue on MultiSim side due to multiple students encountering the same issue.
(3,220 Views)
