Multisim and Ultiboard
Adding a 3-12v dc motor
Hello all,
Just to let you know, I'm new to electronics so please keep that in mind.
My plan is this: press a momentary (NO) switch and turn on two Red LEDs. This is powered by a 9v battery.
I have the circuit working, with appropriate resistors of course.
Now I want to add a small basic two wire 3-12v motor to be be also turned on with the switch.
The motor is a small type, the kind used in toys.
I can't seem to locate that type motor in the components list!
I sure would appreciate any help.
Thanks in advance.
(1,074 Views)
Hello! Feel free to ask questions. If you work in the Multisim program, then it is better to upload the file in the 'ms' format. This will be as informative as possible in order to accurately answer your problem.
There are such motors in the program, and not even one model, and you can make any one for all user requests.
(1,055 Views)
Вот три мотора с внешним возбуждением и с постоянными магнитами. В свойствах можете задать им необходимые параметры.
Вольтметры показывают обороты в минуту на холостом ходу.
(986 Views)
