09-04-2006 03:00 AM
09-07-2006 08:19 AM
10-23-2006 01:59 PM
I found these definitions:
Usually if you don't have a MCU controlling the circuit you would tie together EOC with SOC, so the end of a conversion will trigger the next conversion, and most likely usually you want to have OE tied to a V+ supply if you want the circuit to be generating the digital pattern continuously. The case in which you don't tie the signals as mention is when you want complete timing control on your side, but for basic apps you should be fine like this.
Hope this helps,
