Multisim and Ultiboard
8QAM
Hi every one , Can you help me build a (8 QAM) Octal Quadratic Amplitude Modulation circuit? I am using NI Multisim 14.1. I have built this circuit for QAM, but the output on the Oscilloscope is incorrect. If you can help me, I will be grateful. https://drive.google.com/file/d/1PGs1MJwKBNiq9CaFbdazPPR3wdP86nG_/view?usp=drive_link
(931 Views)
To build an 8-QAM modulator in Multisim, you'll need to generate I and Q signals, mix them with carrier signals, and sum the outputs. Use an oscilloscope to visualize the constellation diagram and a spectrum analyzer to analyze the frequency spectrum. Check signal levels, carrier frequencies, and component values carefully. Refer to Multisim documentation for detailed guidance.
(849 Views)
