Multisim and Ultiboard
74hc14 relaxation oscillator
I wanted to simulate a circuit using a standard 74HC14 relaxation oscillator using a resistor and capacitor.
The NXP datasheet (page 17) says that for a 74HC14 the frequency can be determined by the formula F = 1/T = 1/(0.8*RC).
Unfortunately the simulation doesn't seem to give results that match this.   I wanted to set up a relaxation oscillator with a period of about 66mS, and with an 825k resistor, working the formula backards gives a value of about 100nF.
If I use a 100nF capacitor, the actual period for the oscillation that the MultiSim simulation creates is about 157mS, and I need to reduce the capacitor to 43nF to get the period to be 66mS.
I attach an MS10 file showing the problem.
The second relaxation oscillator and 74HC393 are there to actually get the simulation to do anything at all - without these the output of the upper circuit sits a 5V all the time.
(6,683 Views)
Hi David,
Attached is a circuit that is oscillating and to make it run I change the simulation method from trapezoidal to gear, this setting is under Simulate>>Interactive Simulating settings>>Analysis Options>>Customize>>Transient.  Unfortunately, getting this circuit to oscillate at the correct frequency is difficult and this is usually true with many self-oscillating circuit in any SPICE simulators.   In Multisim, you can tweak the rise/fall time on the 74HC14 by double click on the component and select the Edit Model button under the "Value" tab this should have some affect to the oscillating frequency.
Tien P.
(6,654 Views)
