10-06-2006 11:13 AM
10-06-2006 03:08 PM
10-06-2006 03:17 PM
10-13-2006 08:44 AM
Hi Phillip,
In Ultiboard, to create a connector select tools--> Library Manager.
There are two columns, library and parts. On the part side click on the first
icon which is the "new" icon. You should get a dialog box with
the option to select new PCB parts.
When you are in the footprint edit mode, the place menu should have everything
you need.
Select Place-->Footprint pins to place your footprint. On the right
side of the dialog, you will see row/column, enter the number of pins for each
row/column. The field beside this is center to center distance for each
pad.
Once you have everything, define just place in on the work area.
To draw silkscreen, make the silkscreen layer the active layer. Under the
place menu, select shape to draw whatever shape you want.
The question “X?” is your default reference ID location, place this at the
appropriate location. The other “?” is for the value of the component, usually,
I don’t put this on the PCB board and I make this invisible.
Once everything is setup save it to your database, make sure the name of the footprint you use is the same as the name of the footprint in Multisim.
Tip: Use the asterisk (*) key on the number pad, don't press
shitft+8. This function allows you to enter exact coordinates. If
you need to place your pad at a specific location, use this. The
center on the pad will go the coordinate that you entered.
10-13-2006 09:28 AM
Thank you very much for the help. It is easy to make active spice models. I have not been able to make mechanicle models. I did find a PCB model maker. But it will be realsed in December for Ultiboard. Th price is kind of steep. $1575. It is called I think PCBlibraries. It only works on SMT products. I will work on creating the model tonight. It is one of thise things that bugs you until you get the problem resolved.
Thank You
Philip
