I am trying to simulate 300V AC voltage controller with restive load using SCR from Multisim SCR library. But the output is not correct. The waveform shows that the reverse SCR does not conduct at all even the firing angle is applied at 180 degree.The problem is with negative half.
Pls guide someone....
