Multisim and Ultiboard
Reply
2-Phase Stepper Motor as a Generator
Good Afternoon,
I am designing a circuit which uses a 2 phase stepper motor to charge small devices such as cell phones. I am trying to simulate the power output, but am not sure of the results, or if the stepper motor in Multisim can be used as a generator. I have attached my current design of the circuit. Am I approaching this the right way? Any help would be appreciated!
Thank you!
(140 Views)
Highlighted
Re: 2-Phase Stepper Motor as a Generator
Hi ticotinr,
I think you need to change the simulated battery for a load instead of using a source. I did this and measurements seemed to have more sense.
It seems that the rectification stage needs some refinement but if you use a load instead of a source, you should be able to see the power output of the motor.
Warm Regards,
Enhernan
(106 Views)
