Multisim and Ultiboard
1. Can i have heli pot (slow changing resistance potentiometer) in multisim 2. How can i make a variable bar (e.g. in case of variable resistance) vertical in multisim
dr_parjit@hotmail.com
(3,519 Views)
It is not possible for users to create interactive components in Multisim. You have to use the interactive and parametric components provided in the Master Database.
If you want to see the output of a circuit on different resistance levels of a resistor, you can use a simple resistor and then run a Parameter Sweep on the circuit and see the output of the circuit at different resistance levels.
Tayyab R,
National Instruments.
(3,469 Views)
Hi
Thanks for response
How can i make  a variable bar/slid bar  (e.g. in case of variable resistance) vertical in  multisim
To my earlier you have not devoted time. So once again I request to you
1. Please double click the attached file
2. check circuits for AM and PWM they are not working properly
3. Can u send me circuits for same if u ahve already
waiting for your good response
Parjit Sandhu
(3,463 Views)
