Multifunction DAQ
write data into fifo and output at the same time, pci 6711
I am now communicating with PCI 6711 DAQ card by using LabVIEW 7.1. I tried to write a 2-d array -- many <x,y> values -- into the FIFO on the PCI 6711, and the <x,y> values should be outputted one by one to the 2 analog outputs -- x to AO0 and y to AO1 at the same time, depending on the hardware clock (or the trigger). Can anyone tell me, if it is possible to do this. If yes, how? I have got the figure by using DAQmx, but i don't know if they are being outputted really at the SAME time and if it is independently from software (I mean LabVIEW or Windows).
OS: Windows XP Pro with SP2
Software: LabVIEW 7.1
Hardware: PCI-6711
Jiong
(2,644 Views)
There are plenty examples installed with your driver. Check the following folder on your computer:
...National Instruments/LabView 7.1/examples/DAQmx/Analog Output/Generate Voltage.llb
Inside the .llb are various VIs, using internal or external clocks, different triggertypes etc.
Here you can find an example, that shows how to output multiple channels:
http://zone.ni.com/devzone/cda/epd/p/id/5001
Hope this helps!
André
(2,633 Views)
Thanks for the SUPER quick answer Smiley Very Happy
I'll try it again
(2,630 Views)
