01-17-2007 07:49 AM
01-18-2007 03:36 AM
There are plenty examples installed with your driver. Check the following folder on your computer:
...National Instruments/LabView 7.1/examples/DAQmx/Analog Output/Generate Voltage.llb
Inside the .llb are various VIs, using internal or external clocks, different triggertypes etc.
Here you can find an example, that shows how to output multiple channels:
http://zone.ni.com/devzone/cda/epd/p/id/5001
Hope this helps!
André
01-18-2007 05:10 AM
Thanks for the SUPER quick answer
I'll try it again
