I'm looking for conect a standard encoder with power supply equal to 12Vdc, so also the two output channels will be with 12Vdc square vawe output. Are there some problem with the PFI8 & 10 suggest for this function using 12Vdc (is the max level equal to 5,25 or 20Volt?)
Thank you for cooperations
