Multifunction DAQ
what is the delay clock on a 6052E board
Ok, silly question: Using the WFM_ClockRate function, on a 6052E board, to set up a continous output from a memory buffer, what is the "delay clock" in this context? Does it have a meaning, or should I just set it to zero and forget about it? The update clock is the clock used to time the output waveform (one sample per tick), I presume.
(2,830 Views)
Greetings,
You will want to set this parameter to zero. The delay clock (also known as the interval clock) is used for pulsed waveform generation. You can use the delay clock to set a time interval between cycles during which NI-DAQ does not produce update pulses.
Good luck with your application.
Spencer S.
(2,830 Views)
