Multifunction DAQ
what is a typical level of noise on a 4 - 20 mA signal?
Thanks everyone for your input. This has been a very productive discussion for me.
I think I can conclude that the 4-20 mA signal is not be suitable for my application. Even if I am able to eliminate the noise or mitigate it through averaging the "range accuracy" of the AI card is not adequate.
aeastet, I take your point that the laser unit is probably averaging the raw data before transmitting it over the serial port, giving the impression that the data is free of noise. I hadn't considered this.
For future applications I will use a rough rule of thumb that a 4-20mA signal is good for transmitting signals with a resolution accurate to about 0.3% (0.049/16) of full scale. My application requires an accuracy of at least 0.06% (1/1600) of full scale which appears to be way outside the capabilities of a 4-20 mA signal.
I can also conclude that the resolution of a device does not imply a level of accuracy.
Message 11 of 12
(1,577 Views)
A tough lesson to learn!  We all try to get more out of our equipment than is really possible from time to time.  Even us engineer type foget to oil up our slip-sticks on occasion
"Should be" isn't "Is" -Jay
Message 12 of 12
(1,574 Views)
