Multifunction DAQ
what hardware should I use to transmit signal to a controller from computer
I have a Labview application running on my laptop and it acquires data from a UWB receiver to measure distance from transmitter via USB. There are 3 zones  safe, warning and Danger . according to the distance between them like the stack light tower(predominantly Red, Yellow and Green) used in Industries for status monitoring. Now I would like to transmit the control signal to a real light tower(I dont have it yet but could be 30VDC) from my computer.
Which hardware should I use for this? Is a Bus powered DAQ suitable for outputting signals or a RIO device?
(3,161 Views)
you can use any DAQ that have analog output combination of use one signal conditioner or amplifier to reach your desired voltage
(3,136 Views)
I would think you would want digital outputs, one each for each light in the tower.
The USB-6525 has SSR digital outputs rated up to 60VDC at 500mA.
http://sine.ni.com/nips/cds/view/p/lang/en/nid/203343
-AK2DM
(3,123 Views)
beas on your light tower you can use analog or digital output as AnalogKid2Digital man told
(3,107 Views)
