Multifunction DAQ
voltage spikes on analog outputs of 6255 and 6071E
I am using PCI 6071E and PCI 6255 boards in desktop PC’s, and have been observing large voltage spikes on the analog output channels. A typical pair of spikes is shown in the attached file (amplitude 4 V, main spike width ~100 ns). The AO0 and AO1 outputs of a PCI 6255 from a SCB-68 connector block were connected to an oscilloscope with 1 MOhm impedance, without any other load attached.
The spikes occur occasionally (once every couple of hours to a day). Spikes occur at various times, when the PC powers up, when the PC is on and not running any programs, and also when Labview VI’s are loaded but not running. I have not observed any spikes when Labview VI’s are actually running.
System details: Desktop PC, Windows 7 (32 bit) with 4 GB RAM. Labview 2009 and MAX 4.6 installed (but not necessarily running, as I mentioned). Two PCI 6255 and one PCI 6071E installed.
I have observed similar spikes on two other similar systems with PCI 6071E cards. I'd greatly appreciate any insight into this problem.
Sumit
(3,704 Views)
Accepted by topic author sumitm
Hello Sumit,
I tried opening the image file you provided, but was unable to.  Could you try uploading that again?
Also, I have a few questions that might help us pin down the problem:
1) Do you see the same behavior when you have already loaded and run a VI (i.e. you run, then close the VI)?
2) Do you see the behavior after opening a test panel to the card in MAX?
3) What drivers are you currently using? You may want to consider downloading a more recent version of your drivers, which can be found here:
https://www.ni.com/en/search.html?pg=1&ps=10&sb=%2Brelevancy&sn=catnav:sup.dwl.ndr
You may also want to ensure that the drivers are configured to load at boot, rather than at first call.
4) Have you tried observing the output across a load?
In the meantime, I would recommend self-calibrating the cards in MAX.
Tom L.
(3,680 Views)
Thanks, Tom. Updated the drivers, and I haven't seen any spikes in a while.
(3,632 Views)
