Multifunction DAQ
using counters on a PCI60-14
I've a PCI-6014 board, with labview 6.1 on Windows
I'd like to use two different and independant counters on two pfi lines (see the attach file)
I'am able to use only one, as in the examples, but I don't understand why.
Could you help me to realize 2 independant counters please.
Thanks.
(2,519 Views)
Have you tried configuring two different counter setups. In other words, duplicate what is shown in your example, but with one addition. Wire in a different group number for each counter in the "Counter Group Config.vi". Otherwise you will be trying to reconfigure the same group. And of course you'll need different PFI and RTSI lines for the "Counter Source (STC).vi"
Doug Norman
(2,519 Views)
