01-07-2021 11:27 AM
I plan to use a PXI-6230 and PXIe-4141 for a triggered measurement.
the plan is to use the DAQ to take the external TTL trigger, route it to backplane. PXI_Trig0-7, and use it to trigger SMU for measurements.
any one have any idea how to do this? I'm using C# for development.
thanks
01-09-2021 07:22 PM
You can do it as shown below in LabVIEW, in C# it will be similar, just that you would need to know the format of the terminal for the trigger.
If you are not too specific about which PXI_Trig line to use, you can use this method, DAQmx and PXI Platform services does a dynamic route between the source terminal and destination automatically.
Use the below trigger source format when configuring the Measurement Trigger on the SMU session.
/<PXI6230instrument_alias>/<PFILine>
01-09-2021 08:00 PM
Great! thanks for the reply.
I just figured out how to use connect terminals in C# today and routed PFI0 from PXI-6230 to PXI_trig0.
I'll receive my SMU module next week and I'll try your method. I hope it will work.
I wish NI has a complete manual to show how to use those modules like Keithley does, not just help files and examples.
01-15-2021 10:06 AM
it works well like what you suggested. thank you
01-18-2021 09:26 AM
Good to know that your query was addressed. Please mark the appropriate reply as the answer to close this thread.
