10-23-2008 12:45 PM
Hi friends,
I am having a DAQ-6009 which I want to use for measuring load values from two load cells together by connecting them to two separate analogoue input channels. I have generated a labview code which can read and show input from any channel.
I tried calling the vi twice in the "main vi" inputting separate analogue input channels in their controls which obviously did not work since DAQ 6009 cannot do simultaneous acquisition. Can anyone suggest a way of accomplishing the same without using separate DAQ cards. Slight time difference of the order of milliseconds in between two measurements will be acceptable for me.
Thank you,
Partha
10-23-2008 01:38 PM
10-23-2008 02:08 PM
Hi Dennis,
I got this one; but for further signal processing or writing the subsequent processed data in a binary format what should be my approach?
Thank you,
Partha
10-23-2008 03:06 PM
10-23-2008 03:14 PM
Dennis,
I want to get a time averaged value of the signals ; which I want to differentiate to get the rate of change of load. This data, I will be using to control my stepper motor velocity
so that the rate of load change is constant.
So basically, I need to be able to separate the two streams of data , analyze them separately and then use it to control my stepper motor.
Thank you,
Partha
10-23-2008 03:37 PM
