04-11-2006 07:29 AM
04-13-2006 10:03 AM
04-22-2006 09:28 AM
Thanks, Mike
Can you please check why the attached code does not work with USB9233.
I am trying to take a few triggerred measurements. The attached code works with PCI 4474, but not on USB 9233.
On USB 9233, it takes the first set of data and then the USB 9233 hardware becomes disconnected (the LED either "Not lit" or "On, not blinking"). I suspect that USB 9233 does not allow more than one "start task" and "stop task". I can "clear task" and then re-config everything after each measurement, but is there better alternative? Thanks.
Ian
04-22-2006 09:53 AM
04-24-2006 07:46 AM
04-24-2006 01:54 PM
04-25-2006 12:09 PM
Hey Ian -
The DAQmx Help has some good information on the state model of the DAQmx driver and decribes what each of the states (including Commit) means. Search the .chm with "state model" and you'll get the info pretty quick.
Also, here's a DevZone document which answers some higher level questions about the differences between DAQmx and Trad DAQ:
http://zone.ni.com/devzone/conceptd.nsf/webmain/EE47B125BB9E053686256FBC0014C384
What happens when you use the Commit with your USB-9233? Does it stop acquiring, etc?
-Jack
