05-02-2007 09:15 AM
05-02-2007
05:29 PM
- last edited on
05-06-2024
03:28 PM
by
Content Cleaner
Hi Jon-
The screw terminal area on USB-625x devices does not include a breadboarding area. If you need an easy solution for building external front-end circuitry I would indeed recommend the USB-6251 mass termination version with an SCB-68 terminal block (or similar) and a shielded 68-pin cable.
Hopefully this helps-
05-03-2007 07:54 AM
10-02-2008 02:32 AM
Hello all,
if I understand correctly: the "screw term" version has screw contacts onboard: I can connect a thin wire directly to the DAQ lines. On the other hand, the "mass term" version needs a supplementary cablesold by NI.
Is that correct?
Many thanks to all, regards
10-02-2008
07:24 AM
- last edited on
05-06-2024
03:31 PM
by
Content Cleaner
xdaf,
You understand correctly. Check out the datasheet and it's corresponding product page for pictures and specifications.
