usb-600xx RS-232
I'd like to create a test device with multiple sensors and actors, whereby one device communicate by rs-232.
I didn't found any information regarding this, thats why the question:
can I use a usb-600xx device to communicate with RS-232?
Thanks!
(1,719 Views)
No.  Get a USB-RS232 adapter.  There are some out there that are pretty cheap.  I have had good luck with the TU-S9.  If you want more reliable, StarTech has some good industrial grade adapters (I am a fan of the ICUSB2324I).
GCentral
(1,694 Views)
thanks for the reply!
some years ago I / we had problems with those converters.
Is this still an issue or are there no problems with those converter any more?
(1,679 Views)
I find it to be a hit-or-miss for most converters out there.  I state these two because I have had success with them on multiple systems.  If you are on a desktop and have the PCI(e) slots, I would recommend NI's RS-232 cards (they are on the higher price, but are definitely industrial grade).
GCentral
(1,667 Views)
