12-15-2021 04:23 AM
Dear Users,
we use in our Physical Practice at TU Kaiserslautern at several experiments the USB-6008 to read signals. Now I need a substitude and I read, that USB-6008 will not be buyable in future. I read the specifications of USB-6008 and USB-6001, and it seems, that the specifications of USB-6001 can substitude the USB-6008. But I am confused about the following detail:
USB-6008 says "Analog Input ..., software selectable", but unfortunately USB-6001 not the same.
For reading the signals I create a task with NIDAQmx, and use this task in Labview.
Is this possible too with the USB-6001?
Sorry for my bad English and thank you in advance
Bernd
12-15-2021 09:18 PM
If you describe how you are going to use this DAQ, we can help in verifying if it is possible.
Anyway, 6001 being an entry-level DAQ is not a direct 1-1 replacement for 6008, but if your requirement is simple enough, it may be satisfied by 6001.
12-16-2021 03:05 AM
Thank you for your quick answer.
The problem for us is to know the possibilities before buying the usb-6001.
Our requirements are simple. Only to measure 2 voltages in difference, not single ended.
If the channels are multiplexed and its possible to pick the main channels than usb-6001 will accomplish our requirements.
On the other hand i'll contact NI if it is possible to get remainders of the 6008, because we have already 10 in action.
Kind regards
Bernd Stabel
