06-23-2008 03:48 PM
06-24-2008 12:50 PM
Hi George,
I understand that you are using the USB-5133 digitizer; do you want to generate the pulse when you start or stop acquisition? Or based on what event do you want to generate this pulse? It would be helpful if you can give us more details about what you are trying to accomplish. You can use the NI-Scope Export Signal VI to generate the pulse in the PFI1 line. But look on the USB-5133 Routing Matrix the specific signals that can be exported. The Help for the USB-5133 can be found by going to Start > Programs > National Instruments > NI-SCOPE > Documentation > NI High Speed Digitizers Help. There, under Devices you can find the NI 5132/5133 Overview. I hope this is helpful,
06-25-2008 08:26 PM
06-26-2008 03:22 PM
Hi George,
The parameters of the pulse generated by the PFI1 line are correct, if you verify in the 5133 Specifications the Logic Type of the Output pulse is 3.3. V CMOS, and the Minimum Pulse Width is 100 ns. I understand it is not possible to programmatically change the duration/magnitude of that pulse. Regarding a way to reliable produce that pulse, I noticed in your VI that you Initiate the Acquisition and then Fetch the Waveform, but you don’t close the Scope session at the end of your application. I suggest using the niScope Close.vi at the end of your application, when you are finished using the instrument driver session. I hope this is helpful,
