unable to use App Builder DLLs with Visual Basic -- NIPALU
I found in ur knowledge base that there was a problem in NIDAQ 6.9.1 that was supposed to be fixed with the next version. I am using 6.9.2f8. I can run the VB .exe, but this makes debugging a pain.
(2,226 Views)
Nicole,
Which problem are you reffering to? Do you have a KnowledgeBase document ID? Also; I'm not sure I understand why debuging the exe would be a pain.
Sorry I was not able to help more, please elaborate on your problem and I may be able to do something.
Amaury R.
Applications Engineer
(2,226 Views)
link to KB ID:
http://digital.ni.com/softlib.nsf/954feaeea92d90918625674b00658b83/ab94b3a08673e33286256af100588e07?OpenDocument
It is a pain to debug the VB exe because I cannot use the normal debugging tools provided in the VB interface if I can only launch the executable to try it out. Imagine trying to debug a VI without the debugger.
The problem is that when I load Visual Basic and use it to call a DLL created by NI App Builder, I get an error "unable to initialize NIPALU.DLL". I am able to successfully run the VB executable from the command line.
Thanks for your help.
(2,226 Views)
