Multifunction DAQ
two edge separation without hardware aux input
I am using a PXI-6229 DAQ card with C# .net.
I want to do a two edge separation measurement without a hardware input into the counter aux port.  I want the counter aux input to start when an event happens (in this case it is turning on a signal generator) and then stop when a digital input goes high to the gate.  There is no hardware digital input to start the aux input counter.  Is there a way to start the counter manually at the same time the a software command starts the signal generator?  The code would be something like this:
public void MeasureTime()
            DigitalTask = new Task();
            CIChannel counterSetup;
            firstEdge = CITwoEdgeSeparationFirstEdge.Rising;
            secondEdge = CITwoEdgeSeparationSecondEdge.Rising;
            double minTime = 10e-3;
            double maxTime = 60e-3;
            string auxCounterInput =?
            string gateCounterInput = "/" + CardName + "/PFI8";
            counterSetup = DigitalTask.CIChannels.CreateTwoEdgeSeparationChannel(
                CardName + "/ctr0", "counter",
                minTime,
                maxTime,
                firstEdge, secondEdge, CITwoEdgeSeparationUnits.Seconds);
            counterSetup.TwoEdgeSeparationFirstTerminal =?
            counterSetup.TwoEdgeSeparationSecondTerminal = gateCounterInput;
            //Start task and turn signal generator on
            DigitalTask.Control(TaskAction.Verify);
            runningDigitalTask = DigitalTask;
            counterInReader = new CounterReader(DigitalTask.Stream);
            double data = counterInReader.ReadSingleSampleDouble();
(4,350 Views)
Could you please clarify your end goal of this application? What do you mean by doing an edge separation measurement without using a hardware input? We can set up triggers to start DAQ tasks. Can the signal generator be started with a pulse? Can the signal generator output a pulse at startup?
Jason H
Automated Test Software R&D
(4,318 Views)
Hi Jason,
My end goal is to measure the time from when the signal generator is turned on until a signal goes high on PFI8.  I have no way of connecting a hardware signal to the aux counter input to start the count.  There is no way for the DAQ to monitor the signal generator turning on.   Is there a way to start the counter using a sw trigger that will coincide with turning on the signal generator?
Thanks.
(4,314 Views)
Have you looked at the .NET examples we have on triggering? If you are using Windows 7, they are located in C:\Users\Public\Documents\National Instruments\NI-DAQ\Examples. You can use these as a reference to get the proper syntax for triggers.
Jason H
(4,292 Views)
