Diagnostic run after using MAX to reset the same board. These failures to "configure the device" are the way the board has been failing during its measurement application. Does this mean the board itself is bad, or is there a software trick to reconfigure it?
- - - - - relevant diagnostic output - - - - -
Running Calibration ... FAILED for the following reason:
Error -200329 occurred at DAQmx Self Calibrate.vi
Possible reason(s):
An error has occurred while attempting to configure the device for an analog input acquisition.
If an external master timebase is being used, make sure the source is connected and generating an appropriate clock. Otherwise, contact National Instruments Technical Support.
Testing AI Ground Reference... (FAIL)
************ Test FAILED for the following reason ************
Error -200329 occurred at DAQmx Start Task.vi
Possible reason(s):
Testing AI Voltage Reference... (FAIL)
Possible reason(s):
Testing AI Finite Sample Clock... (FAIL)
Error -200329 occurred at DAQmx Control Task.vi
Possible reason(s):
Testing AI Finite Sample Clock Frequency... (FAIL)
Possible reason(s):
Testing AO Single Point... (FAIL)
Error -200329 occurred at DAQmx Read (Analog 1D DBL 1Chan NSamp).vi
Possible reason(s):
Testing AO Accuracy... (FAIL)
Possible reason(s):
