Multifunction DAQ
test panel 6036E
I have install a DAQcard-6036E I can see it in MAX (Devices and interfaces --> Traditional NI-DAQ Devices --> DAQCard-6036E (Device 1) )
but I do not have access to the test panel. Is it normal ? (I know that test panel does not work for every devices)
And I can't access any software NI (only MAX)
I've try to unistall/re-install but i do not work...
thanks for your help !
(3,793 Views)
Based on what you said, I believe that happening because one driver is missing or needing update.
Best Regards,
César Teixeira
Certified LabVIEW Developer - CLD
Applications Engineering
National Instruments Brazil
(3,755 Views)
