Multifunction DAQ
take ten measurements with a delay between them of a certain time and find the average
Hi everyone,
I am Vasileios and I have a question for you!
I want to take ten voltage measurements with a DAQ assistant and between them to have a delay of one second. And afterwards out of these ten volage measurements to find the average between a maximum and a minimum value. In the end I want to save the final value.
I would appreciate your help!
Regards from France,
Vasileios
Message 1 of 10
(5,619 Views)
Do a finite sampling with 10 samples at a 1Hz frequency.  From there, use the Array Max & Min to get your maximum and minimum values.  Add them and divide by 2.
Message 2 of 10
(5,616 Views)
Hi
Thank you for yuor reply. nonetheless I would like to solve my problem creating an array out of these 10 measurements (putting the daq assistant inside a for loop for ten) and then after I do the addition of the ten measurements I deivide with ten in order to find the average.... But to be honnest  that is my initial plan and I face a lot of difficulties... 😞
Can you give me another solution???
Thanks again!
Message 3 of 10
(5,609 Views)
Your method sounds like it will work too.
Have you tried coding this up?  Care to share any code you have done?
Message 4 of 10
(5,607 Views)
Hey again and thanks for your reply,
Although I haven't done a lot of progress I could say , I am attaching you the vi.. Actually I am still concerned which array functions I should use since I cannot figure out how to make an array of ten measurements...
Feel free to make any changes!
Additionally from the same daq assistant I have two channels and i want to do the same thing for both channels... but I maybe think about it in a later stage..
Message 5 of 10
(5,603 Views)
Something like this?
Message 6 of 10
(5,597 Views)
Hi!
Can you please share with me (and all the others) your VI?
I will try to see if I will have the expected results 🙂
\Vasileios
Message 7 of 10
(5,586 Views)
The image is a snippet (look it up) and can be dragged to a block diagram. The code is about as simple as it gets, though. You've got the Convert From Dynamic Data, an Index Array, and two Mean functions.
Message 8 of 10
(5,579 Views)
Thank you for your replies. Finally after spending sometime discovering new things in labview I made out the below selection 🙂
Message 9 of 10
(5,534 Views)
Try to avoid the use of local variables.  They are additional copies of your data and they break data flow.  LabVIEW is a data flow language.  Use wires whenever possible.
Message 10 of 10
(5,532 Views)
