Multifunction DAQ
synchronous acquisition
hi
          im using the pci-mio-16E1 card, with the IDE VC++, so  im looking for an example to explicate me how to make an synchronous acquisition data using an external timing, so the idea is to acquire the data from the  input channel at each cycle  tigger,and saving  the data in a file .
now im making a code with the AI_setup and DAQ_op functions, im getting  a speed acquisition ,it is the start of acquisition data, and  it is  a synchronous acquisition just for one cycle (trigger), and me i looking for an acquisition for all the cycle of signal trigger.
 tank  you to help me.
(3,008 Views)
You need to learn how to edit your posts, so you don't keep making new threads. You can also simply reply to your own posts. If you keep making new threads, the answers will get lost.
"AI_setup and DAQ_op functions"
Can you use NI-DAQmx? It's easier, and more future-proof. See my answer to one of your other threads.
John Weeks
WaveMetrics, Inc.
Phone (503) 620-3001
Fax (503) 620-6754
www.wavemetrics.com
(2,995 Views)
Please see the following thread for responses to this post...
http://forums.ni.com/ni/board/message?board.id=250&message.id=13623
(2,976 Views)
