(I already posted this question in the Labview forum without much reaction as that was the most appropiate forum for this question)
Dear,
I have to synchronize 2 DAQ boards in a PXI rack. After some searching
on the internet I'm a bit confused, there seems to be a lot of
different solutions to solve the problem ... but it depends on the
actual configuration of the set-up. I would like some advice which
solution is the most suited:
I have in a PXI rack the following boards:
PXI NI 6123, S Series Multifunction DAQ (responsible for capturing 5 analog signals with also the triggering channel)
PXI NI 4220, SC Series DAQ With Signal Conditioning (1 full bridge connected)
Software: labview 7.1 and NIDAQmx 7.1
If this is working, I'm going to write everything in Matlab code such
that I can do the measurement directly from Matlab (this is already
working for only the PXI 6123 card)
