08-30-2006 05:46 PM
08-30-2006 08:29 PM
08-31-2006 10:32 AM
Most Analog outputs on DAQ cards are current limited to the range of 5-10mA. And if you short the output, the voltage differential between AO+ and Gnd will be 0 volts.
Not sure of potential damage to the DAQ when shorted.
08-31-2006 03:42 PM
11-14-2022 08:23 AM
Well, in my case I need to measure a high pass filter of a large batch of circuits.
There might be a short at some point and in order to not break a card worth a minivan I'd like to find out if a short might break it.
I am using a NI6281 USB Card, but nor the M Series User Manual as well as the DEVICE SPECIFICATIONS datasheet provide information about shorting the output.
Is there a schematic for the output like for the MyDAQ ?
