Multifunction DAQ
scxi-1600 no ready led blinking
Dear All
I have a SCXI-1000 with scxi-1600, and many time ago I had a problem with it and in that time was the inside fuses.
Now the problem is different, the SCXI-1000 has power, the SCXI-1600 has the 2 v+ and v- led turned on but the ready led no.
I tryed with other SCXI-1600 and the system is recognised as normal, seems everything ok with scxi-1000.
I opened the scxi-1600 but has no signal that has a fuse inside.
Any suggestion
Best regards
cpalha
(4,677 Views)
Dear All
No ideas please.....
cpalha
(4,622 Views)
Hi cpalha,
If you can swap in the second 1600, without changing anything else, and the system works properly, then the first 1600 is likely in need of repair.  A few things that you might try first:
  • Plug into a different USB port on the PC.
  • See if the system works properly with another PC.
  • Move the 1600 to a different slot in the chassis.
If none of these steps lead to a change in behavior of the module, please contact your local branch to set up a repair for your device.
(4,612 Views)
