Multifunction DAQ
scb-68 cjc with analog input
Can the SCB-68 terminal block be used to measure an analog voltage input when the switches are configured to enable the temperature sensor for differential inputs?  Is a calculation performed on all voltage inputs for cold junction compensation when the switches are enabled?
(2,657 Views)
jenkya101,
This Knowledge base article addresses your question.
Hope this helps!
Abhinav T.
Abhinav T.
Applications Engineering
National Instruments India
LabVIEW Introduction Course - Six Hours
Getting Started with NI-DAQmx
Measurement Fundamentals
(2,642 Views)
