refresh rate of the daq-pad 6016
Hello everybody,
I am using a DAQ 6016 and 2 DAQ 6009. My problem is that the refresh rate of the 6016 is very slow if I put two analogic channels to read.
I asked for a sampling rate of 20KHz and 25 samples for both channels, which should last only 1.25ms each. The samples are fine, but the graphs or the values refresh only less of 5fps. In the same time, if I run the DAQ6009 with the same configuration, it refresh faster. If I put more channels, the 6009 refresh stay more or less the same, but with 7 channels the 6016 refresh 1 time every 1 or 2 seconds.
An other test was: 400Hz +-10V to one analogic input, and I just asked for a single point in a loop. The chart couldn't allow me to see the 400Hz, so the equivalent sampling should be at least more than 10S/s.
I could also see that it sampling wasn't steady.
I use a P3 900 MHz as computer with 512MB RAM, USB 1.1, and tried on a P4 1.8GHz, 512 MB and USB2.0 for the same results.
Does someone see what could be the problem?
Greetings
Laurent
Message 1 of 11
(3,792 Views)
Hi Laurent,
It is difficult to narrow down your issue without having a glimpse at your code. Would it be possible for you to post a screenshot of your code or the LabVIEW code itself?
Abhinav T.
Applications Engineer
Abhinav T.
Applications Engineering
National Instruments India
LabVIEW Introduction Course - Six Hours
Getting Started with NI-DAQmx
Measurement Fundamentals
Message 2 of 11
(3,767 Views)
thank you for replying, abhinav T Smiley Wink
I link here a screenshot of the most basic program:
    10 samples at 10KHz for both of the DAQ assistants, with make the acquisition of aio of the 6016
the displays refresh something like 4 times per second, whereas one acquisition should last 1ms.
On the other hand, i tried to emit one bit and mesure the time up to its reception (I linked 2 hardware channels together). Almost each time, I have a delay of 15ms
Smiley Sad
Any idea what could it be? I already ran 2 times the autocalibration
Laurent
Message 3 of 11
(3,752 Views)
Laurent,
Is there any reason why you're using 2 DAQ Assistants?
Can you try using a single DAQ Assistant instead or one of the example programs in the NI Example Finder (Help >> Find Examples...)?
Abhinav T.
Abhinav T.
Message 4 of 11
(3,733 Views)
hum, well, the reason is just that I didn't realise it was possible... I belived it would make an error. Whatever, thank you very much for that, because you just helped me for another problem Smiley Wink
But for the refresh problem, it seems that the 6016 prefer 1000 samples at 100KHz than 10 samples at 1000 Hz. Is there a way ti find the optimised frequency and rate?
Laurent
Message 5 of 11
(3,718 Views)
Laurent,
I have tested the DAQpad-6016 at the settings you described and everything works fine. Can you try acquiring one waveform using the configuration in the image attached, (just measure one channel at 1kHz and acquire 100 samples per channel)?
Abhinav T.
Abhinav T.
Message 6 of 11
(3,691 Views)
