Multifunction DAQ
"merge signals" with variable number of input signals
Hello everybody,
I receive analog signals (max 8 channels) via a NI USB-6008. I read the signals with a DAQ-Assistant. With the "Merge Signals" - function I merge the different channels to one combined signal and I save this combined signal via the Express-VI "Write to Measurement File".
No problems until now.
But I would like to be more flexible. With buttons on the front panel, I would like to choose, which channels to save which ones not to save. So maybe I want to save channel 2 only, and during the next measurement I would like to save the channels 1, 3 and 5 for instance.
In the attachement you find a simplified version of the labview-file (Labview-version: 8.2). Instead of the DAQ-Assistant you'll find the constants 1 to 5.
I'm thankful for any possible solution for the issue.
zuzy
(3,840 Views)
Hi zuzy,
you forgot your attachment. Here is a simple example, i´m unconvinced with it, but maybe it helps. I think a better solution would be to use the DAQmx functions.
Mike
(3,834 Views)
Hi Mike,
Yes, I forgot to upload my file. Thanks for your answer. As I can see that you understood my troubles. The problem with your solution is, that there are 32 possible combinations to distinguish. So quite complex to achieve. I would be happier with an easier way to do it. But thanks again for your effort!!
Best regards, zuzy
(3,828 Views)
Hi zuzy,
an easier way is to use the DAQmx vi´s. There you can receive your data as an array of waveforms, so that you can index the signals which you want to save to a file.
Mike
Message Edited by MikeS81 on 04-08-2008 01:03 PM
(3,822 Views)
sir i have d following 2 vi
1st is a tracing vi which i got when i downloaded d drives for spectrum analyser and d other is a basic amplitude measurement vi
how can i get d visa source output be given to d 2nd vi so dat i can measure d real time signal coming from d spectrum analyser
(3,439 Views)
Please don't hijack a completely unrelated thread. Especially since you've already hijacked a different thread - http://www.ni.com/download/ni-visa-14.0.1/5023/en/
And learn to spell 'the'.
(3,424 Views)
