08-19-2020 03:07 AM
Hello everyone,
I bought a new multifunction card PXI 6115 and I want to test the voltage generation function.
As the fugure below, I wrote a simplist wave generation program. I set the amplitude to 1 and start the program. It can actually generate a sine wave. But when I change the amplitude to 2 while the program is running, the card can not generate the new wave with amplitude 2V. Earlier I have used cDAQ NI 9263 for analog voltage generation with the same program. But there was no such problem. For attachment I also wrote a program without DAQ assistant, in whch I also specified the write buffer.
Best regards
Yang Sun
Solved! Go to Solution.
08-24-2020 06:45 AM
I'm unable to open the VI that you have attached but I have try to find relevant link here.
Did you try this link before (On The Fly Waveform Configuration with DAQmx) :
https://forums.ni.com/t5/Example-Code/On-The-Fly-Waveform-Configuration-with-DAQmx/ta-p/3491040?prof...
The link provided contain some samples VI too.
12-04-2020 12:46 AM
