01-19-2006 01:57 AM
01-19-2006 11:27 AM
maincool:
Right now I would not worry about your ground 2 question, but usually if grounds are uniquely labelled, they would then refer to the same point. For example all GND1's are connected together, all GND2's connected together. GND1 may or may not be connected to GND2. You can always ohm it out with a meter to be sure if you have one available.
Please verify if that L(220VAC) connection is correct. If it is, I expect you will see fireworks when it is powered up.
