Multifunction DAQ
pci 6259 card cable selection
i had pci6259 m series card and a scb68 screw terminal i need to connect these two with a cable,i had sh68-68d1 pt.no 183432-01 can i connect with this cable.
does 186381A-02 SH68-C68-S will work for pci 6259 m series board and scb68.
(3,739 Views)
Hi ajay200126,
Thanks for the post and I hope your well today.
In short, yes it will work.
The SH68-C68-S is designed to be used with National Instruments motion boards and is not recommended for use with M Series cards because it does not provide as much sheilding as the SHC68-68-EPM. However, it is still a cable option for M Series boards.
* The SHC68-68-EP cable is intended for E Series DAQCards (PCMCIA only), but will also work with M Series devices. The SHC68-68-EPM cable is recommended for M Series because it gives better protection against noise on the digital lines of the M Series boards.
Hope this helps,
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(3,738 Views)
thanks 4ur reply waht about  sh68-68D1 cable for use
(3,735 Views)
Thanks for getting back to me - I hope my advice found you well.
The D1 has D-type connectors - these won't connect to the pci 6259."The shielded 68-conductor cable terminated with two 68-pin female 0.050 series D-type connectors. This cable connects counter/timer devices to the accessories."
I would recommend looking at this knowledgebase,
Cabling Options for M Series
http://digital.ni.com/public.nsf/allkb/23B19403451923BF86256F34004E1D3D
The cables you can use are,
SHC68-68-EPM
SHC68-68-EP
SH68-C68-S
SH68-C68-S
RC68-68
SHC68-NT-S
Hope this clears things up for you.
Kind Regards
James Hillman
(3,728 Views)
