Multifunction DAQ
noisy (+-100C temp spikes) readings with SCB-68 and T-type TC.
I am getting very noisy readings of a T-type thermocouple with the SCB-68.  I was going to solder in a low pass filter and noticed there was already doides soldered in positions F and G for all channels.  It seems like these were installed at NI.  Can these be removed?  I have a picture I can email.
  -Jenya
Message 1 of 9
(3,885 Views)
I think those are not diodes, but actually zero ohm resistors. In the SCB's user manual, refer to CH4- Thermocouples, CH5- Adding Components and Appendix D- Circuit diagrams to aid in component selection and insertion.
Here's a link to the manual:
https://www.ni.com/docs/en-US/bundle/scb-68-getting-started/page/scb-68-about.html
You may also need to crank up the gain for the channel you are using to abtain accurate readings, these signals are quite small in amplitude.
Message Edited by AnalogKid2DigitalMan on 10-23-2006 09:52 AM
Message 2 of 9
(3,881 Views)
Thanks for the response.  Is it possible to control the gain of the SCB-68?  I didn't see anything about gain control in the manual.
Message 3 of 9
(3,875 Views)
The SCB is just a terminal block, the gain is set up by your Data Acquisition Hardware (DAQ). What is the model number for that?
Message 4 of 9
(3,872 Views)
Hello, I am using the PCI-6023E.
Message 5 of 9
(3,869 Views)
The 6023 can bee programmed for full scale inputs of +/-10V, +/-5V, +/-1V and +/-.1V. Suggest you try starting with 1 or .1 range.
https://www.ni.com/docs/en-US/bundle/370503k/resource/370503k.pdf
Message 6 of 9
(3,865 Views)
  I've already set the limits to -50C to +100C (-2.81 to 4.28mV).  Looks like the low pass filter may be the only option left for signal conditioning.  Can I remove the 0 ohm resistors in positions F and G to solder in the filter?  The filter requires that I use either F or G.  Should I remove both 0 ohm resistors or just one?
Thanks for the help.
Message 7 of 9
(3,861 Views)
Jenya,
Thanks for contacting National Instruments.  That's right, you can remove the 0 ohm resistors.  The reference to the manual earlier in the post describes this.  I would reccomend you read through it.
Kenn North
Principal Product Manager - Search, Digital Analytics
http://ni.com/search
Message 8 of 9
(3,838 Views)
Thanks Kenn,
  I'll try it out.
Message 9 of 9
(3,835 Views)
