Hi Dennis,
Thank you so much for your help. I am new to the LabVIEW. I just got the software and the PCI-5114 board last Fri.
My application is that using the PCI-5114 to measure 2 input voltages automatically and save the results to files.I chose the leaving Window Trigger mode in order to record the data which is higher than +0.5V or lower than -0.5V.
The device is used to record the 2 voltage signals contineouly. How should I set the hardward's timeout value?
The acquired data will be analyzed by MatLab. Which format is better, .lvm, .tdms or .tdm?
The attached file is the VI I made.
Best Regards
Min
Message Edited by mbei on
05-12-2008 02:53 PM
