I have done a complete setup of CDs including labview and device drivers. I use a PCI 6014 with BNC2110. when I launh the DAQ assistant in labview, in the "my pysical channel" labview doesn't find any supported device. Can you help me to solve this problem?
I don't know if i'm in the correct section.
My aim is to use the BNC2110 to acquire a signal but also to generate a signal with caracteristic that you can change in real time.
When I use the measurement and automation explorer I manage to acquire a signal and to generate one.
When I take an example I have this error on labview:
Error -200220 occurred at DAQmx Create Channel (AI-Voltage-Basic).vi
Possible reason(s):
Device identifier is invalid.
Device Specified: Dev1
Task Name: _unnamedTask<0>
Thank you.
PS: I have done a mistake I post this msg in another not correctsection
labview 7.0
