I need help for this big problem. I have a LabView application running in a PC with a Intel Core 2 processor with dual PC express 2.0x16 slots (DP45SG Intel's Motherboard).
About more or less 24 hrs it works fine, but suddenly the system crashes and shows the blue screen. I have two PCI-6229 cards connected, NiDAQmx 8.7, labView 8.5, and Measurement & Automation Explores 4.4 installed.
That sounds like a memory leak. The most common reason is because the programmer does not use good programming techniques. Could you send me your program to check it through?
* I can see that your profile is in Mexico, so if you prefer we could switch to Spanish.
