05-10-2010 04:06 PM
Our Labview application collects analog data using a niusb6009 Multifuncion I/O. The application is proven, and has been in production for years.
Today, the application stopped receiving analog data. After shutting down the application, shutting down our computer w/ Windows XP Pro SP2.
The Computer and Windows was restarted. When opening our LabView Application, the following error was displayed:
nidevmon.exe Error: "The Application failed to initiate properly (0xc0000142) Click OK to terminate application.
Solved! Go to Solution.
05-11-2010 11:35 AM
Howdy Scuba Steve!
Is there anything that could have been changed software/hardware-wise on the machine prior to this error occuring? Also, what version of LabVIEW and DAQmx are you using?
The nidevmon.exe error could be caused by a number of different things. Please look over this KnowledgeBase article for possible solutions to the problem.
10-03-2018 04:00 PM
this KB link no longer works. can someone at NI please provide a new link to this KB article??
10-04-2018 09:59 AM
Hey try the steps given in this KB: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8iMSAS
If this step doesn't work then I suggest you uninstall and reinstall NI software.
