03-15-2005 10:12 AM
03-16-2005 06:13 PM
03-17-2005 10:42 AM
03-21-2005 12:13 PM
03-21-2005 12:50 PM
@Ayman K wrote:
Pat,
Change detection is only supported in the NI 653x family. These boards are supported under Traditional NI-DAQ, and DAQmx (only with NI-DAQ 7.4). However, they are not supported by DAQmx Base.
Ayman K
03-21-2005 01:43 PM
03-21-2005 02:01 PM
@Ayman K wrote:
Pat,
What is the operating system in which you are developing your application? From what I understand, you are restricted to the use of DAQmx Base maybe because you are developing your application in a Linux machine that is only supported through DAQmx Base. However, if you are running windows, you could have both drivers installed in your system (DAQmx and DAQmx Base). Please advise me of this operating system you intend to use these boards in.
Ayman K
03-23-2005 09:25 AM
03-24-2005 11:01 AM
03-24-2005 12:16 PM
